I’m planning to visit France in the summer. The connection quality between providers varies a lot in the region I am visiting (rural Nièvre). Which provider will my SIM card connect to while roaming in France?
What network does iD mobile use in France?
Best answer by Siân
France is one of our free Roaming destinations which means that you can use your monthly data allowance and add-ons at no extra cost, up to 30GB. Make sure you connect to Societe Francaise Du Radiotelephone, Bouygues, Orange or Free Mobile as they are the roaming partners.
We hope you have a fab trip!
Reply.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
