why cant i use my phone from USA to ring uk? if i need to increase my limit how do i do it?
  • June 13, 2024
  • 232 views
Karen Andrew
Currently in USA and am unable to use the phone. How do I make it work so I can call uk and use data?
Best answer by Tom
Hi @Karen Andrew
Your bill cap will need to be high enough to support the extra charges a call from the USA to the UK would cost, you’ll be able to change your bill cap in the iD Mobile app/website.
Charges associated with using your plan in the USA can be found below;
  • 8225 replies
  • July 1, 2024
Hi @Karen Andrew
