network data issues in PO40 area
Matt_p
No internet in PO40 area freshwater, isle of wight since 29th Feb 2024…. How long before a fix???
Matt_p wrote:
Thanks Kev I will give them a ring, yes I've seen maintenance in the area but no idea how long for .. cheers for the reply 👍
Three UK might be working on their 3G network switch-off in your area, @Matt_p. If they are, then the cell towers and backhaul network might be pinch-points while works are in-progress.
Not sure it’s possible to get a factual report on the network status in your area, via iD Mobile.
  • March 4, 2024
Hi @Matt_p
I feel your pain. I was in the same position this time last month for a week. Have you tried contacting iD mobile directly? I rang them on 0800 049 2402 to raise a complaint. Not sure if it helped speed up the resolution, but I did, eventually, get some money back.
Also, have you looked on 3's Network status checker, since iD use their network?
Hope things are back to normal for you soon.
Kev.
Matt_p
  • March 4, 2024
  • 12550 replies
  • March 5, 2024
  • 8256 replies
  • March 6, 2024
Hi @Matt_p,
We can’t provide any information on issues in the area without the full postcode.
However if you have raised a complaint the team will investigate it and get back to you.
If you would like us to check it out, please let us know.
