F.A.Q.
What is Mobile Data and how can I control my usage?
  • March 19, 2020
  • 33752 views
iD Mobile
Contents:
Whether you’re streaming YouTube or scrolling through social media, you’ll be using data. But what is it, how do we measure it and what do you need to know?
What is Mobile Data?
Mobile data is what allows your phone to connect to the internet when you’re not connected to Wi-Fi. You can use it to browse the internet, download music or videos and run apps while you’re on the go.
How is Mobile Data measured?
Data is measured in kilobytes (KB), megabytes (MB), and gigabytes (GB). A byte is one unit of data, with 1,024 bytes equaling a kilobyte, 1,024 kilobytes equaling a megabyte, and 1,024 megabytes equaling a gigabyte. Data usage is tracked in KB, with both upstream (sending) and downstream (receiving) data contributing to your total usage.
How does iD Mobile calculate how much Mobile Data is used?
We use an Online Charging System (OCS) to track how much data you use. When you use Mobile Data on your phone, your device seeks permission from our OCS, starting a data session charged according to your plan. Your data session may stop if you use up your allowance or reach your bill cap.Data charges are based on both upstream and downstream data.Because of this, there may be times when your device uses some data we can’t measure. This means that your device may give a different reading of how much data you’ve used.
How do I check my Mobile Data allowance?
The quickest way to view your remaining allowances is in the iD Mobile app or on my.idmobile.co.uk. Here, you can view your remaining allowances for Data, Minutes and Texts. Alternatively, you can call our automated telephone service (7777 from your iD Mobile SIM or 0333 003 7777 from any other phone). Check out the Community article below for more helpful information:
How can I control my Mobile Data usage?
Sometimes you can use more data in a month than you expect to, which can leave you with an unwanted bill. Here’s a few ways you can control your Mobile Data usage:
  1. Enabling ‘Low Data Mode’.
Using ‘Low Data Mode’ can help reduce your data usage by limiting background activity and automatic updates. Here’s how to enable it on different phones:
I’m using an iPhone:
Learn more
  1. Open Settings.
  2. Tap ‘Mobile Services’.
  3. Tap ‘Mobile Data Options’ or if you have more than one active SIM (physical or eSIM), choose your iD Mobile line.
  4. Tap ‘Data Mode’.
  5. Select ‘Low Data Mode’.
I’m using a Samsung Galaxy:
Learn more
  1. Open Settings.
  2. Tap ‘Connections’.
  3. Tap ‘Data Usage’.
  4. Tap ‘Data Saver’.
  5. Check that the 'Turn on now' toggle is turned on.
Most other Android phones:
Learn more
  1. Open Settings.
  2. Tap ‘Network & Internet’.
  3. Tap ‘Data Saver’.
  4. Check that the 'Use Data Saver' toggle is turned on.
  1. Use streaming services offline.
You don’t need Mobile Data to enjoy your favourite shows and music. Apps like Netflix, Prime Video, Disney+, Spotify, and Apple Music let you download content to watch or listen to later. Just connect to WiFi, find what you want, and download it. Simply visit their websites to learn more about offline mode.
  1. Set a Bill Cap.
Bill Capping is a money-saving feature on all iD Mobile plans. It lets you limit your monthly spend to an amount that works for you. Simply set your Bill Cap in the iD Mobile app to limit additional charges, and we won't charge you more than the amount you set as your Bill Cap. Check out the Community article below for more helpful information:
Which sites and apps don’t use up your data?
Some websites and services arefree-rated, meaning you can use them without being charged for data (unless you're using a VPN). These include:
URL
999bsl.co.uk
999bsl.com
999bsl.me
999bsl.net
999bsl.org
999bsl.org.uk
999bsl.uk
attendanywhere.co.uk
bsl999.co.uk
bsl999.me
bsl999.net
bsl999.org
bsl999.org.uk
bsl999.uk
childline.org.uk
community.idmobile.co.uk
containers.appdomain
dcg-prd-as-proxy.eu-gb.ace.ibm.com
digital.nuance.com
emergencyvrs.co.uk
emergencyvrs.com
emergencyvrs.uk
emergencyvrs999.co.uk
emergencyvrs999.com
emergencyvrs999.uk
esim-3uk-es-uat.ipaas.amdocs.com
esim-3uk-wsht-prd.ipaas.amdocs.com
esim-3uk-wsht-uat.ipaas.amdocs.com
esim-es-sim.prod.tuk.esimcloud.net
galop.org.uk
gig.cymru
gov.uk
hscni.net
huk-livelab.prod.ondemandconnectivity.com
huk.prod.ondemandconnectivity.com
inq.com
malesurvivor.co.uk
nationaldahelpline.org.uk
nhs.attendanywhere.com
nhs.wales
nspcc.org.uk
porting.idmobile.co.uk
rapecrisis.org.uk
refuge.org.uk
thesurvivorstrust.org
touchcommerce.com
victimsupport.org.uk
welshwomensaid.org.uk
womensaid.org.uk
20% found this helpful
