I recently left I'd as the coverage is poor in the area, I requested my PAC code and did the port to Lyca mobile ever since I can not receive SMS messages and can't make voice calls to some numbers (RCS messaging and internet seems ok and people seem to be able to call me) Have been told its a porting issue and I need to report it to the provider i have just left - i have reported it to Lyca mobile but 3 days in and no updates or progress - please help have health issues and not sure I am getting messages through from Doctor so it's pretty urgent
Call and SMS issues after porting
Best answer by Natalie W
Hello
We are sorry to hear you are experiencing issues following the port of your number.
Once the port is completed from our side, we are not able to run diagnostic checks on issues you may be facing as this will need to be completed by your new provider.
We would however recommend trying the following steps to see if they help.
For iPhone:
For Android:
Alternatively, you can turn Chat Features/RCS off and test SMS after this
Nat
Log in to the iD Community.
Social Login
Log in with FacebookPlease enter your email address. If it matches our records, we'll send you instructions to reset your password.
