Call forwarding/Call divert is not working?
  • 10 replies
Hello,
I did some research on iD mobile, and read here, here and here that call forwarding/divert is supported. So I signed up today! However, I cannot get call forwarding to work at all.
I am using a Google Pixel 6a, with this month’s software update. I am using an iD mobile eSim. WiFi calling is working, and I have setup voicemail. I can make and receive calls OK, and get 4G/LTE coverage at my location.
I’m trying to enable call divert by:
  1. Opening the android dialer (phone icon).
  2. Opening Call forwarding menu ( Menu icon > Settings > Calling accounts > iDmobile > Call forwarding.
  3. The phone briefly shows “Reading settings...” and then shows a forwarding number for ‘Always forward’, ‘When busy’, ‘When unanswered’ and ‘When unreachable’. The number shown ends in 123 (voicemail?) for all options except ‘Always forward’, which shows as ‘off’.
  4. I select ‘Always forward’ and enter a phone number (a UK mobile number in the format +44xxxxxxxxxx) and select ‘Turn on’.
  5. The phone shows “Reading settings...” for around 1 minute, before giving the error “Network or SIM card error.”.
I tried a few times, in different locations (on a different Cell base-station), and in Airplane mode with WiFi calling enabled, but always get the same result.
I need call forwarding to work - can anyone help?
Best answer by JustEddy
I think I might have had some sucess.
Not using my phones divert setting, but a dial sequence.
I dialled *002*UKNUMBER#     e.g. *002*01232543876#
The result screen showed all as successful.
Upon checking with *#002# it does show Voice call forwarding, All Calls as Enabled.
  • 10 replies
  • February 11, 2025
I tried getting support via the live chat. They suggested I repeat the same steps again, restart my phone and also try using the MMI codes (*72), none of which worked. Their final suggestion was to speak to Google to get help resetting the phone.
I found that it is possible to do a reset of the mobile network settings in Android (Settings app > System >  Reset Options > Reset mobile network settings). I did this, but that didn’t help either.
I noticed that when I try to set call forwarding, the phone switches to 3G temporarily and gives the error “Unexpected response from network”. If there is no 3G coverage, I get the error “Network or SIM card error”.
Is call forwarding on iD working for anyone else?
Forum|alt.badge.img+21
  • 2255 replies
  • February 16, 2025
Hello ​@0xe9
We are sorry to hear you are experiencing issues with call forwarding.
Could you please provide the following information?
  • Is the number you are attempting to forward to in the UK?
  • Have you test the feature using another number?
  • Are there any issues receiving calls aside from the forwarding problem?
Please do let us know and we will do all we can to assist further.
Nat
  • 10 replies
  • February 16, 2025
Hi Nat,
I’ve tried forwarding to a few numbers now:
  • a UK mobile number - as described in my original post,
  • a UK landline number,
  • the voicemail number “+447782333123” - as is set by default for the ‘When busy’, ‘When unanswered’ etc options.
In all cases I get the same error messages as described above, and forwarding doesn’t happen.
There are no issues receiving and making calls.
  • 4228 replies
  • February 17, 2025
Hey there ​@0xe9, we’re very sorry to hear that.
If you’d like, we can send you a PM to investigate further and potentially raise further to our technical team?
  • 10 replies
  • February 17, 2025
Hi Tyler,
Yes, very happy to work with you to try and figure out what the issue is. While I use it infrequently, I really need call forwarding to work for those rare times that I depend on it.
  • 12380 replies
  • February 18, 2025
Perhaps 3G shutdown has highlighted an issue with call forwarding functionality, using 4G network infrastructure, ​@0xe9.
I wonder if call forwarding is ‘programmable’ from a user device, using the iD Mobile IMS package (needed for 4G Calling and WiFi Calling).
It’s possible iD Mobile will need to contact Three UK (their UK mobile network partner), for assistance with this problem.
  • 10 replies
  • February 19, 2025
Interesting you mention that, ​@andewhite. My previous provider (GiffGaff) broke call forwarding functionality for me and many others recently during their rollout of WiFi calling. GiffGaff only support WiFi calling for a limited number of recent phones, and my 2.5yr old Google Pixel 6a is not one of them. That, I am told, is the reason I can’t setup call forwarding from my phone anymore on their network
Hence, when I read that iD mobile support call forwarding, I switched over. WiFi calling on iD mobile works great on my Pixel 6a, but I’m starting to worry that call forwarding might not actually work anymore here either.
Maybe someone out there can try it out and see if they have the same issue as I am having?
  • 12380 replies
  • February 19, 2025
Hopefully another forum member can help, ​@0xe9. I doubt iD Mobile will be able to resolve this issue, but perhaps they’ll prove me wrong.
I believe Giffgaff can provide call forwarding, but you need to contact the giffgaff agents to get it adjusted/setup, which is somewhat inconvenient.
  • 2255 replies
  • February 21, 2025
Hello ​@0xe9
Thank you for your reply.
We have sent you a private message that should be available via your inbox 📪
Please let us know if you have any issues accessing the message.
Nat
  • 10 replies
  • February 24, 2025
I met with a friend at the weekend who happens to have the same phone (Pixel 6a) and is also on ID mobile. I had them try setting call forwarding up by following the steps in my original post.
Interestingly for them, it appeared to work. The setting applied and no error was displayed. The call forwarding icon appered in the notification area. We didn’t actually test that a call was forwarded, but it is certainly a step forward from where I can get.
Our phones were running the same software build (AP4a.250205.002.A1) with the same security patch applied. The only real difference I can see is that they were using a physical SIM, whereas I am using an eSIM.
I tried requesting a new eSIM, which I received and applied. This had no effect on the call forwarding issue.
So maybe next I will try a physical SIM instead.
  • 2255 replies
  • February 25, 2025
Thank you for updating the thread ​@0xe9
If you would like to proceed with the order of the eSIM, please do pop over the request in a private message.
Nat
  • 10 replies
  • February 26, 2025
Hi Nat,
I have requested a physical SIM in the private message chat.
  • 4228 replies
  • February 27, 2025
Hey there ​@0xe9, no problem at all.
  • 10 replies
  • March 3, 2025
So, I received the physical SIM today, installed it, and activated it successfully.
Unfortunately, the issues with call forwarding remain as with the eSIM. I'm still getting the same error messages when trying to set call forwarding.
  • 8408 replies
  • March 3, 2025
Hi ​@0xe9
Taking a look we’re already in PMs with you about this, we’ll update there when possible.
Forum|alt.badge.img
  • March 16, 2025
Did you ever resolve this?
I`m having the exact same issue, I`m close to leaving the network now, but would much rather just have this feature working.
  • 10 replies
  • March 16, 2025
Hi ​@JustEddy, thanks for sharing your experience with this issue. Kinda makes me feel better that it’s not just me…
No resolution so far. I’m getting ‘technical support’ via private messages, but so far, this has just been me proving that the issue is not with my phone. It has been over a month since I reported this issue so I’m also planning to leave, unless a solution is provided quick.
FWIW, I tested out my Google Pixel 6a on the Talkmobile network and everything just worked for me… VoLTE, WiFi calling, 5G, and… call forwarding!
Forum|alt.badge.img
  • March 17, 2025
  • 10 replies
  • March 17, 2025
I tried setting call forwarding again just now and to my surprise - it is now working! I can set and clear call forwarding for all numbers via the phone settings. No errors are reported. I’ve not actually had a call be diverted yet, but looks like everything is now behaving as expected.
@JustEddy Thanks for posting that MMI code. I’ve tried it now and it works as well.
Did something get fixed somewhere?
  • 12 replies
  • May 29, 2025
I am having the same issue on two new iPhone 16 handsets I just bought with iD mobile physical sims.
Also tried the sims in my previous iPhone 11 and a Galaxy - both also fail.
Tried my daughters O2 sim in all 4 handsets and works fine on each one.
I have posted this in another thread and been told by iD it’s a handset issue. Have spoken to Apple who say it’s a carrier issue. My tests would seem to support Apple
Managed to get one of the new 16s to forward using the *002* route but not the other
Has anyone else had success?
  • 8408 replies
  • May 30, 2025
Hi ​@Steve61
