forwarding calls via esim on my samsung
Paolo Carluci
I have a samsung s21 I have tried to Forward my calls to another number through an esim but I am getting an error message. Does anyone know why this is happening.
  • April 17, 2025
What error message are you getting?
Paolo Carluci
It doesn't seem to allow me to even select the option to which is applicable
  • April 17, 2025
Can you try performing a network reset then try again?
  • April 18, 2025
Hey there ​@Paolo Carluci, we’re sorry to hear that.
Have you been able to use call forwarding with us before, or is this a new issue?
Paolo Carluci
It's the first time I am doing it with iD I had no issues previously with a different network provider. Could this be an issue because I am using an esim rather than a physical sim card?
  • April 19, 2025
No! Have you tried resetting your network settings as previously instructed?
Paolo Carluci
Yes have reset mobile network settings and getting the same error message
  • April 19, 2025
I have an eSIM and I can configure call forwarding. Maybe try performing an eSIM swap.
Paolo Carluci
I think that's my only option I can't think of anything else
Forum|alt.badge.img+20
  • April 21, 2025
Hi ​@Paolo Carluci
Have you been able to set this up since your last post on the thread?
Natalie
Reply.
