incominy calls going to voicemail
  • February 5, 2025
  • 9 replies
  • 73 views
All calls are going to voicemail on IPhone SE. Checked do not disturb settings and call forwarding - all off. Help please!!
Forum|alt.badge.img+21
  • 2119 replies
  • February 5, 2025
Hello ​@AJH44
We are sorry to hear all calls are going to voicemail.
Can you please confirm if you are showing as having signal at the time of the calls?
Are texts and data working okay?
Nat
  • February 6, 2025
Yes texts and data ok.
Andy
  • February 6, 2025
Set phone to FaceTime seems to have solved issue but is there something else in settings I need to change to enable ‘phone’ setting?
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • February 6, 2025
Out of interest Andy is your iPhone SE a 1st gen (2016) or a 2nd gen (2020)?
The reason for asking is because this recently modified iD phone compatibility list now states only the iPhone SE 2022 (3rd gen) is compatible. I’m merely relaying what that list states
  • February 6, 2025
My mistake it’s the XR !
  • 12167 replies
  • February 6, 2025
Assuming your iPhone XR device is running iOS 18, have you checked the number shown in Settings > Apps > Phone, ​@AJH44?
  • 2119 replies
  • February 7, 2025
Thank you ​@AJH44
Could you please check your number in the settings as suggested by ​@andewhite ?
The number will need to begin with +44 and not a 0 if possible.
Nat
  • February 7, 2025
Hi. Yes it starts 44 …. Thanks A
  • 2119 replies
  • February 11, 2025
Thank you.
Are you able to pop your SIM in to another handset to test if calls are received?
This will help identify if it is a SIM or handset issue.
Nat
