Hi I have just took out a contract with id is it possible to keep my old number ? If so how do I do this ?
keep same sim
Best answer by Crimson
Hello, you’ll need a PAC code from your previous provider.
steps
1. Text PAC to 65075 from your old number
2. Submit Your PAC Code to iD Mobile
Go to:https://www.idmobile.co.uk/switch
and follow the steps
The transfer usually takes 1 working day dependant on the time of day you submit the form.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
