Hi - I had my number from EE ported to ID when I bought a new phone with them. I didn’t like the phone so returned it minus the sim card. I bought a new phone which had a different contract so was sent a new sim. I wanted to transfer my old number again to the new sim but was told you can’t do that from 2 ID mobile sims.
I decided that I’ll jsut continue giving out my old number as it’s really easily remembered, ie consecutive numbers (I’m getting on as well). Anyway, I jsut haven’t put any credit on the old sim as it’s purely for receiving calls. I’d prefer if ID could jsut change my number but that’s not happening anytime soon if at all. Is it possible that as I’m not paying anything they will remove my original number and put it out for distribution?
Keeping old SIM card without a contract for incoming calls only
Best answer by Tom
If you’re trying to move a number from one iD Mobile plan to another, unfortunately this isn’t directly possible.
It may be worth moving the desired number to another network’s Pay As You Go SIM card and from that to the new iD Mobile plan.
Reply.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
