Motorola G7 Power can't make or receive calls
Bgood
Switched to iD Mobile. Kept my number. Can't make or receive calls. SIM card shows phone number as 'unknown'. SIM card appears ok when placed into another phone. My phone is a Motorola G7 Power Android 10. I've tried all the fixes I can find on this community site.
Anyone had the same issue recently and fixed it?
Daz_S
Gold Contributor
Forum|alt.badge.img+21
  • Gold Contributor
  • 1628 replies
  • January 30, 2025
Hi there ​@Bgood
Sooo, iDM have stated the MG7 Power is “Capable” for both 4G (VoLTE) calling and Wi-Fi calling.
For the most part their compatibility checker is either a yes or a no, therefore they’ve changed the goalposts again.
So with that said have you enabled VoLTE
Refer to the other Andorid phones (click on the learn more) and follow from step 3
Bgood
  • January 30, 2025
Thanks ​@Daz_S
My phone shows preferred network as 4G/3G/2G so I assume Volte is enabled. There's no specific setting for VoLTE
Daz_S
Gold Contributor
  • Gold Contributor
  • 1628 replies
  • January 30, 2025
No problem ​@Bgood
That might be an issue, AFAIK you need VoLTE enabled - I’m not sure if Motorola call it 4G calling. Give me a few mins I have a mate whom has a MG10 Play and I know I set his up for VoLTE I’ll try calling him to see what his says.
Daz_S
Gold Contributor
  • Gold Contributor
  • 1628 replies
  • January 30, 2025
I tried. I asked where his setting is and his reply was that I set it up and thus he doesn’t know!
But he does recall seeing it as an option.
I might have gone via the motorola service engineers menu, but google might show how and where its located.
Bgood
  • January 30, 2025
Thanks ​@Daz_S  Google search just sends me to sites I've already seen and tried the suggested solutions. I'll keep searching!
Daz_S
Gold Contributor
  • Gold Contributor
  • 1628 replies
  • January 30, 2025
Hopefully a staff member can clarify their new terminology of “capable”
But more importantly this means they must have tried it out themselves and if this is the case maybe they can point you in the right direction🤞
Decembersangel72
Silver Contributor
Hi ​@Bgood
You may want to make sure VoLTE is provisioned on your phone by dialing *#*#4636#*#* (using the keypad in ‘calls’). This will open a secret menu so you can see if VoLTE is turned on. If it is greyed out and ‘off’ then you will not be able to enable it on this netwrok.
Looking at the iD Mobile VoLTE ‘approved handsets’ it appears as though your phone has not been tested/approved (N/A). If you have a phone that isn’t on this list, then it may or may not work, but iD Mobile don’t officially support any phones outside of these and cannot say for sure if it will or not.
This also shows if you can enable VoLTE on your phione…
https://videotron.tmtx.ca/en/topic/moto_gpower/using_voice_over_lte_volte.html#step=1
Hope this clarifys things x
