Phone will make call saway from home, but not at home
After months of having no problems making calls from home, my phone will n o longer do this, but was fine when I went into the local Currys store today (about 2.5 miles from home).
Best answer by Tyler
Hey there @Endeavour Graham, unfortunately, the Nokia 8 isn't supported on ours/Three UK’s network for 4G VOLTE/LTE, which means the 3G turn-off would affect your calls altogether if you live in a no 3G zone I’m afraid. Please find supported phones below which will work fine for calling on our networks:
  • 3790 replies
  • November 4, 2024
Hey there @Endeavour Graham, welcome to Community!
What’s your full postcode please?
Also, what phone do you have?
I live in Stevenage and have a Nokia 8
  • 8225 replies
  • November 5, 2024
Hi @Endeavour Graham
Please could you let us know the full postcode(s) where you’re having issues?
The Nokia 8 is supported by iD Mobile, however not for 4G or Wi-Fi calling, with the recent 3G switch offs, usage with your device may be affected.
Post code is SG1 5TT.  I understood that the Nokia 8 was 4G compatible.  Why will it work when I am in Currys, but not at home?
  • November 5, 2024
Post code is B169LG
Phone: Redmi 9AT
  • November 5, 2024
I can't make calls or receive it.
  • November 5, 2024
Yes can't make calls or receive.
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 5, 2024
@Endeavour Graham
In your case 3G has been turned off for your postcode.
And maybe the Curry’s you went to was still in the 3G area?
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 5, 2024
@Mohamed1
For your area 3G appears to be only good outside
Have you read the links posted further up?
If not it’s this one:
And this one:
  • 8225 replies
  • November 6, 2024
Hi @Endeavour Graham & @Mohamed1
Thanks for the help here @Daz_S, it looks like both of you are in areas where 3G is indeed switched off/being switched off, which means devices that are not supported for 4G calling on iD Mobile (Such as the Nokia 8 and Redmi 9AT) may encounter issues with calls going forward.
Hi Daz.  I thought that the Nokia 8 was 4G-compatible and that turning off 3G would, therefore, make no difference.
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 6, 2024
I’m not overly familiar with Nokia’s of today. But in addition to having 4G, any phone NOW* requires the functionality of LTE.
*NOW being since Three (and iD piggyback on Three) started turning off 3G.
So you need to have LTE available on your phone, which in turn IF your phone has this capability then look for a setting like VoLTE and switch/slide it ON. However it could also be the case that your phone was ‘locked’ to your previous provider. As I’m finding even those phones that were locked and have become unlocked (via the PUK method) even these phones cannot have the LTE (or VoLTE) physically turned on as in some cases that option is greyed out. This is due to your previous providers (not phone manufacturer) software inhibiting this function.
So what to do?
Either look around the www for any how to’s regarding removal of that previous providers software (this would entail ‘flashing’ the phone - something most wouldn’t want to try), or see if there’s any good info regarding where that setting may be, or upgrade your phone (an unlocked one) to overcome the loss of calling etc.
edit. Even moving to another provider doesn’t guarantee your phone will work when they also start their own big 3G kill off.
Daz_S
Gold Contributor
  • Gold Contributor
  • 1627 replies
  • November 6, 2024
(so I did reply, then edit and now it’s gone. I’ll see if it shows later)
  • 3790 replies
  • November 6, 2024
