problem with text from abroad
Klaudia Bodnar
Hello. I bought new iPhone . Messages from abroad doesn’t come to my phone and this is very important for me because I have bank account abroad and can not login on new phone because I need text messages to confirm. Spoke with my bank they said the text message have been sent but I haven’t received. In fact I can not use my bank app on new phone . Also my phone doesn’t see my iMessage ( use email address not phone number) also FaceTime. Use apple help but unfortunately nothing works. The worst is missing messages.
Best answer by Tom
Hi @Klaudia Bodnar
Glad to see @andewhite could help you out here, thanks for the help.
Siân W
Forum|alt.badge.img+13
  • 1452 replies
  • November 23, 2023
Hi @Klaudia Bodnar sorry to hear this.
Please check your calling features in the iD Mobile app or My Account online under 'My extras'. When you switch international and roaming on, you'll be able to use these features.
In regards to your other issue, please can you try the following and let us know how you get on?
Klaudia Bodnar
  • 14 replies
  • November 23, 2023
I done all this things . Also I reset my phone with all settings, iMessages still waiting for activation ( phone number) no idea what is wrong. Is it possible that my SIM card can be faulty? The problem with message from abroad also was on my previous phone
  • 12543 replies
  • November 23, 2023
Yes @Klaudia Bodnar, a faulty iD SIM might cause an iMessage activation problem.
Have you spoken to Apple about your iMessage issue?
Klaudia Bodnar
  • 14 replies
  • November 23, 2023
Different card is working normally, I have used all apple support
  • 12543 replies
  • November 23, 2023
Are you swapping the SIM cards in your new iPhone, or are you using a dual-SIM setup @Klaudia Bodnar?
Klaudia Bodnar
  • 14 replies
  • November 23, 2023
I have one SIM card which I used on my old phone . I put the same one to new phone and problem started . I used different SIM card from my friend phone and she put mine to yours phone , her SIM card works with iMessage straight but mine on her phone didn’t work with iMessage on her phone
  • 12543 replies
  • November 23, 2023
Okay @Klaudia Bodnar, have you tried the following steps:
  1. Put your iD SIM card into your old iPhone.
  2. Make sure you're connected to the iD mobile data network.
  3. Tap Settings, then tap Messages. Turn off iMessage.
  4. Tap Settings, then tap FaceTime. Turn off FaceTime.
  5. Turn OFF your old iPhone, and remove the iD SIM card.
  6. Return the iD SIM card to your new iPhone.
Klaudia Bodnar
  • 14 replies
  • November 23, 2023
No . I didn’t… I will now and let know xx
Klaudia Bodnar
  • 14 replies
  • November 23, 2023
I done like above . Problem with activating your SIM card on iMessage and face time … still not working . calls and messages from uk coming normally but my iPhone use my email in iMessage and not working with face time
  • 12543 replies
  • November 23, 2023
Apple do advise activation can sometimes take 24-hours after you toggle iMessage ON.
But, if the iD SIM card is faulty it won’t work.
Is the correct mobile phone number displayed in Settings > Phone > My Number?
Klaudia Bodnar
  • 14 replies
  • November 23, 2023
Yes phone number is correct +44 and rest phone number without zero. I activated new SIM card just in case but not working yet
Klaudia Bodnar
  • 14 replies
  • November 23, 2023
There is mystake during activation, try again 😒
Klaudia Bodnar
  • 14 replies
  • November 23, 2023
I spoke with iPhone customer service. Problem is on ID provider side . They told me to sent message to them number and doesn’t go through 🤬 sms are not configured !!
  • 12543 replies
  • November 23, 2023
Just curious, what number did Apple iPhone customer service ask you to SMS @Klaudia Bodnar
Klaudia Bodnar
  • 14 replies
  • November 23, 2023
48369
  • 12543 replies
  • November 23, 2023
Strange, that is not a UK short-code @Klaudia Bodnar - I would not expect an SMS sent from a UK mobile, to short-code 48369, to work.
Makes you wonder if Apple know what they’re doing.
There’s more about UK short codes online at https://www.short-codes.com/codes/browse.
I believe the number Apple use in the UK, to Send/Receive the iOS iMessage/Facetime activation SMS is: 07786205094 or +447786205094 (to avoid an international charge).
Can you send a random text to this number @Klaudia Bodnar?
Do you get any errors?
I’d recommend double-checking the region of your device is UK and the date & time are correct.
Klaudia Bodnar
  • 14 replies
  • November 24, 2023
No error on that number. O2 network is working on pmt phone
  • 12543 replies
  • November 24, 2023
Okay @Klaudia Bodnar, now you’ve successfully sent test SMS message, to the Apple iOS iMessage/Facetime activation service, at +447786205094, what do Apple UK say?
Klaudia Bodnar
  • 14 replies
  • November 24, 2023
I haven’t got an answer. Should I ring them ?
Klaudia Bodnar
  • 14 replies
  • November 24, 2023
Oh is working now xx thank you so so much
Klaudia Bodnar
  • 14 replies
  • November 24, 2023
What do you think with message from abroad ?
  • 12543 replies
  • November 24, 2023
Are they using your UK number as +44 7 etc?
Do they have an allowance for sending an international SMS?
Klaudia Bodnar
  • 14 replies
  • November 24, 2023
Yes because when I was in bt mobile everything was fine . I have change for ID and problem start but I already downloaded the bank app in my previous network provider and used it. I had app and changed provider for ID and using normally but now when I change a phone I am not able to have bank app because I am not receiving message to activated app… I am not able to change phone number because I need message code and sms doesn’t come to my phone
  • 8552 replies
  • November 27, 2023
Hi @Klaudia Bodnar
