Sim won't work after using esim
I went to Spain last week and used an airalo esim. Now my ID physical sim won't work. Do i need a new sim or can ID get mine going again
MZone
  • 1207 replies
  • April 24, 2025
Have you tried doing a manual roam under network selection. Is the iD SIM switched on in the phone settings if you used an airalo eSIM you may have that as the primary SIM and need to change it back to the iD one?
Siân
Forum|alt.badge.img+8
  • 1323 replies
  • April 24, 2025
Hi ​@Ecb01  hope you had a nice trip!
Are you able delete the foreign ESIM? If your handset still won’t accept it, we can send you a replacement SIM, or you can pick one up in any Currys store.
  • April 25, 2025
So i deleted the esim reset network connections etc. In the end i went currys. The boy there said over the last 6 weeks they've had loads of ppl who have left the UK and on their return their ID mobile sim isn't working irrelevant of having an esim.
  • 4297 replies
  • April 25, 2025
Hey there ​@Ecb01, sorry to hear that.
Did you pick up a replacement SIM card from Currys?
  • May 3, 2025
Yes i did and its all sorted now but it sounds like there's an issue if you leave the UK
Forum|alt.badge.img+21
  • 2255 replies
  • May 5, 2025
Thank you for confirming the issue has now been resolved ​@Ecb01
Please get in touch if we can assist in the future.
Natalie
