SMS won't send, RCS will
  • June 23, 2025
  • 40 views
I am trying to send SMS texts from my old Motorola running Android 11 to my wife (on an iPhone 13 I think).
RCS sends perfectly fine, but if my data drops and I try to send SMS, it just doesn't send. Sending SMS to other contacts works absolutely fine.
Any tips about what I might do?
  • 5782 replies
  • June 24, 2025
Hey there, sorry to hear that ​@Ulfran. Have you tried the following?
Alternatively, you can turn Chat Features/RCS off and test SMS after this.
