I have not been able to use my eSIM on my android phone , I ended up putting it on my husband iPhone , which he also as an I.d mobile eSIM . I want a physical sim in replacement of my eSIM
conversion of Esim to physical sim
Best answer by Mkobello
Yes what I want is to replace my eSIM to a physical sim . How do I do that , I stay I loughborough and can easily go to Leicester . Or what is the cost for sending it over here ?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
