My iMessage and FaceTime will not activate with my ID sim after transferring my number to ID 🤔
iMessage will not activate after transferring (pac) number to ID
Best answer by Dave M
Hope some of this may help you- just resolved my FaceTime /iMessage activation problem yesterday:
After switching to iD and following as much as I was able to (with an eSIM not a physical sim) of the advice on community, iMessage and FaceTime still had activation errors.
I had ported my number from O2.
Some details of what I encountered-
Settings >Apple id >Sign-In & Security
Phone number- was marked as unavailable for iMessage and FaceTime with an info button stating- 'You must have a SIM associated with an Apple device for +447xxxxxxxxxx to be used for iMessage and FaceTime'
I deleted this number which could be done as it wasn't registered.
Resetting Network Settings on my iPhone did not resolve the problem.
My number was correctly showing in Settings>Phone
Erasing and inputting it again did not resolve.
I contacted live chat requesting a new eSIM and they were very helpful and quickly emailed out a new one.
I then again attempted to follow the community advice 'How do I fix iMessage or FaceTime issues after I switched?'
I was unable to untick my Apple id email in Settings>iMessage and also in Settings>Facetime.
I had to put my old O2 sim back in which allowed me to do that.
I deleted my original eSIM
This then cleared my phone number in Setting>Phone
I then followed step 4 in 'How do I fix iMessage or FaceTime issues after I switched?' And waited 30 mins while connected to WiFi.
I then downloaded my new eSIM and waited for it to activate and connect.
Following successful connection, Settings>Apple id>Sign-In & Security showed my number again.
I followed step 5 and it worked perfectly, activating in seconds- iMessage and FaceTime work flawlessly with my mobile number now.
I spent 2 days very frustrated trying to sort this out. I hope this helps someone to resolve a similar issue more quickly.
Having an eSIM did make this more difficult to resolve as I had to delete the old one and request a new one, as opposed to being able to remove the physical SIM card from my phone but it is now resolved without having to wait for a physical SIM card to arrive.
Log in to the iD Community.
Social Login
Log in with FacebookPlease enter your email address. If it matches our records, we'll send you instructions to reset your password.
