iphone not making or receiving calls
  • September 17, 2024
  • 1120 views
Michelle Davies
My iPhone 15 is not allowing me make or receive calls. It is constantly on 2 bars. Really poor service as I can’t speak to anyone. How do I get in a live chat?
Best answer by Tom
Hi @Shaun Pritchard
With the recent 3G switch off, some users are reporting issues with calls, we apologise for any inconvenience caused, we'd recommend the following;
https://community.idmobile.co.uk/3g-200/3g-was-switched-off-in-my-area-and-i-can-t-make-calls-what-should-i-do-60533
Forum|alt.badge.img
  • 9 replies
Same here, they asked me to switch to esim but it did not help. Must be problem on their side.
  • 4266 replies
  • September 20, 2024
Hey there @Michelle Davies & @Voltix, sorry to hear that.
Please can you ensure you’re connected to 4G/4G Volte.
Also, please turn off iMessage, restart your phone, and see if this helps.
Finally, check your phone number is correct in your settings.
Shaun Pritchard
Have not been able to make calls for a few days, probably not receive them either. When I call out nothing just call ended message and a beep after a while. My daughter also on ID is experiencing the same. Im running a work sim in the same phone and thats working fine.
  • 12403 replies
iD Mobile
This iD online article might help.
  • 8408 replies
  • September 24, 2024
Hi @Shaun Pritchard
