issues after transfer of number with messages / i message
I have transferred my number to an eSIM id mobile account. However, I am having trouble with sending messages and connecting to iMessage/FaceTime on my iPhone. My messages are not sending and when I try to re-connect iMessage or set network settings etc, it says ‘activation unsuccessful’ . How can I fix this as I am unable to contact anyone through SMS or iMessage currently.
  • 12344 replies
  • April 28, 2025
If both your SMS text messages and Apple iMessages aren’t working, sounds like an issue with your iD account or SIM, ​@Sarahgiff
Have you tried a NETWORK RESET on the iPhone with your iD SIM. Your iOS user guide explains all the reset procedures.
This community article might help.
  • April 28, 2025
Hiya, yep done multiple network resets and still not working for me!
  • 12344 replies
  • April 28, 2025
Okay ​@Sarahgiff, with iMessage and FaceTime TURNED OFF, can you send and receive SMS text messages?
  • April 28, 2025
Yes, I can send SMS when turned off
  • 12344 replies
  • April 28, 2025
Okay ​@Sarahgiff, with iMessage and FaceTime TURNED OFF can you receive SMS text messages?
  • April 28, 2025
Hi ​@Sarahgiff
Please let us know how you get on with the information that ​@andewhite and we can advise further if required.
  • April 28, 2025
Hi, yes I can recieve and send SMS messages
  • April 28, 2025
Hi, after porting my number to ID network, iMessage and FaceTime won't activate.
I ran the SMSC check using #50057672# and it returned "Unknown Error," meaning my SIM isn't correctly provisioned for SMS services.
i went to Chat gtp and it started the network provider needs to reset my SMS services, refresh my provisioning, and ensure the SMSC settings are properly applied to my account?
  • 12344 replies
  • April 28, 2025
Okay ​@Sarahgiff, you’ve said you can send and receive SMS text messages with iMessage and FaceTime turned OFF, so the SMSC number is correct.
https://support.apple.com/en-gb/108758
This Apple support article might help. I suggest starting at section “Remove your phone number”, then go to “Set up your phone number”.
The Apple iMessage and FaceTime services can take up to 24-hours to be activated according to Apple.
  • April 28, 2025
Hi, I tried to follow the steps to remove the number but it is not showing up and unable to activate iMessage or FaceTime so maybe the reasoning why ‘send/recieve’ is not showing up.
I attempted the SMSC again and it is stating ‘error performing request - unknown error’ so not sure what is going on
