Do you VoLTE enabled on your phone? You need to connect to LTE (AKA VoLTE - Voice over LTE) to make/receive calls. 4G is only a label given to the 4th Generation network but LTE is the type of connection used.
You could also try requesting a replacement SIM as this could be the problem. Please be aware that your account will be put on hold (you will be unable to use that number) until the new SIM has been activated.
There are a few different ways to get a replacement SIM. Here’s everything you need to know:
How do I get a replacement SIM?
If your SIM card doesn't fit your phone, or it's been lost or stolen, you’ll need a replacement. To get a replacement SIM card, you can:
Visit any Currys store.
Find your nearest store and head to the ‘Mobile’ section. One of our helpful Tech Experts will issue you a replacement SIM card.
Chat to us.
Our Live Chat team are able to issue you a replacement SIM card, which will be sent in the post to the account holder’s address.
Once you receive your replacement SIM card, you’ll need to activate it. Check out the steps in the article below:
If this is not the case for you a replacement sim card would be your best option. You can get a replacement card by visiting a Curry's store if there's one near to you or log into you IDMobile account and request a replacement sim card.
Hey there @Dilbahadur Somai, we hope the kind advice from @JoeKing has been able to help thus far.
As mentioned by @JoeKing, a replacement SIM card is definitely worth trying to resolve this issue. These can be collected from any Currys store, or by asking customer services to send either a physical SIM via post, or eSIM via email.
Reply.
Not the answer you were looking for?
Create a new topic and ask a question to the iD Community.
