mr
  • February 21, 2025
  • 8 replies
  • 89 views
where can I get a PUK Code
Best answer by MZone
MZone
  • 1207 replies
  • February 21, 2025
  • 4228 replies
  • February 24, 2025
Hey there ​@phillip kissick, we hope the kind advice above from ​@MZone has been able to help.
Please let us know if you need anything else.
SIM card not working
Tried every other options to make it SIM work but no joy SIM doesn’t work any other mobiles too. However other SIM Card does work on current handset.
Decembersangel72
Silver Contributor
Forum|alt.badge.img+12
Hi ​@Dilbahadur Somai
When you say that the SIM card is not working… is it for everything i.e. calls, texts, data etc or just for some things?
Have you checked the coverage for your area?
Which network is the ‘other’ SIM card from?
What phone do you have?
Is your handset on the ‘Approved List’ for use with the 4G/VoLTE network?
Do you VoLTE enabled on your phone? You need to connect to LTE (AKA VoLTE - Voice over LTE) to make/receive calls. 4G is only a label given to the 4th Generation network but LTE is the type of connection used.
You could also try requesting a replacement SIM as this could be the problem.
Please be aware that your account will be put on hold (you will be unable to use that number) until the new SIM has been activated.
There are a few different ways to get a replacement SIM. Here’s everything you need to know:
How do I get a replacement SIM?
If your SIM card doesn't fit your phone, or it's been lost or stolen, you’ll need a replacement. To get a replacement SIM card, you can:
  • Visit any Currys store.
Find your nearest store and head to the ‘Mobile’ section. One of our helpful Tech Experts will issue you a replacement SIM card.
  • Chat to us.
Our Live Chat team are able to issue you a replacement SIM card, which will be sent in the post to the account holder’s address.
Once you receive your replacement SIM card, you’ll need to activate it. Check out the steps in the article below:
Let us know how you get on x
Calls, texts and data are not working.
Lebara is another SIM card which works.
iPhone 11 and IPhone 6s
JoeKing
Silver Contributor
Forum|alt.badge.img+9
  • Silver Contributor
  • 374 replies
  • March 9, 2025
@Dilbahadur Somai  Sim card not working if you've had a replacement sim card already this sim card needs to be activated link below.
https://my.idmobile.co.uk/activate-sim-outside
If this is not the case for you a replacement sim card would be your best option. You can get a replacement card by visiting a Curry's store if there's one near to you or log into you IDMobile account and request a replacement sim card.
Joe
  • 4228 replies
  • March 10, 2025
Hey there ​@Dilbahadur Somai, we hope the kind advice from ​@JoeKing has been able to help thus far.
As mentioned by ​@JoeKing, a replacement SIM card is definitely worth trying to resolve this issue. These can be collected from any Currys store, or by asking customer services to send either a physical SIM via post, or eSIM via email.
