my roaming in Poland doesn’t work
  • July 12, 2026
  • 23 views
My roaming in Poland doesn’t work for data. I have ticked all the right boxes at still I cannot browse anything. Is there any problem on your end?
Forum|alt.badge.img+16
  • July 13, 2026
Hi ​@MacF,
We're sorry to hear you're having trouble using your data while roaming in Poland.
First, could you check that your phone is connected to one of our roaming partners:
  • Orange
  • Play
  • Plus
  • T-Mobile
You can manually select a network using the steps below.
For iPhone:
  1. Go to Settings > Mobile Service (or Cellular).
  2. Tap Network Selection.
  3. Turn Automatic off.
  4. Wait for the available networks to appear and select Orange, Play, Plus or T-Mobile.
  5. Restart your phone after connecting.
For Android:
(Steps may vary slightly depending on your device.)
  1. Go to Settings > Connections or Network & Internet.
  2. Tap Mobile Networks.
  3. Select Network Operators.
  4. Turn Select Automatically off.
  5. Choose Orange, Play, Plus or T-Mobile from the list.
  6. Restart your phone.
If you're still unable to use data after trying the above, please let us know:
  • The make and model of your phone.
  • Whether calls and texts are working.
  • Whether you've received any roaming welcome text messages since arriving in Poland.
We'll be happy to help further.
