need help!
  • August 28, 2024
  • 49 views
I can’t make calls!!
Hi @Sophie_786 👋🏻
What phone do you have? (as you may need to ‘Google’ the correct details for your device as they may differ from the below information).
Even though you see 4G this may not be the correct option to connect to the ‘4G’ network.
You need to see ‘LTE’ or ‘4G Calling’ for example, rather than just 4G, to be able to connect to the VoLTE (4G Voice over LTE) network which is what the providers use once 3G is turned off.
Do you see an option in the settings to switch VoLTE/4G Calling on?
Please see the reply I gave in this post to see if it helps clarify the problem!
Good luck x
  • 5294 replies
  • August 30, 2024
Hey there @Sophie_786, we’re very sorry to hear that.
How long has this been an issue for please?
Have you tried restarting your phone?
Have you tried resetting network settings?
Decembersangel72
Silver Contributor
Forum|alt.badge.img+13
  • Silver Contributor
  • 377 replies
  • August 30, 2024
Hi @Sophie_786 👋🏻
Good luck x
  • 8256 replies
  • September 3, 2024
Hi @Sophie_786,
I hope your issue is resolved.
