I can’t make calls!!
need help!
What phone do you have? (as you may need to ‘Google’ the correct details for your device as they may differ from the below information).
Even though you see 4G this may not be the correct option to connect to the ‘4G’ network.
You need to see ‘LTE’ or ‘4G Calling’ for example, rather than just 4G, to be able to connect to the VoLTE (4G Voice over LTE) network which is what the providers use once 3G is turned off.
Do you see an option in the settings to switch VoLTE/4G Calling on?
Please see the reply I gave in this post to see if it helps clarify the problem!
Good luck x
Reply.
