network
KingSabaroche
I've been having problems with my ID Mobile data connection and ability to make phone calls for the past 7 days.  I've been on the network since February 2025 and the connection was great but now unable to read to load an article or do anything. I have tried switching phone off and on but makes no difference and need the connection as have young kids so need to be contactable at all times.  There are others in the area that have the same issue.  When will the issue be resolved and when can I be compensated or can I be excused from the 24 month contract as need network connection and the ability to have phone calls. How do I speak to someone at ID Mobile to resolve this issue.
Best answer by Siân W
Hi ​@KingSabaroche  sorry to hear this. Have you checked the links ​@MZone  had sent, as these will show if there are any mast works on-going in your area at the moment.
MZone
  • 1218 replies
  • May 23, 2025
To speak to someone use the iD online Live Chat service.
The advisers work until 8pm on weekdays and 6pm on weekends - just tell the 24/7 chatbot you’d like to “talk to a person”.
Siân W
Forum|alt.badge.img+13
  • 1376 replies
  • May 23, 2025
KingSabaroche
  • May 23, 2025
Where do find the links?
MZone
  • 1218 replies
  • May 23, 2025
Look at the 2nd post
  • 4825 replies
  • May 26, 2025
@KingSabaroche please let us know if you’ve managed to locate them.
Forum|alt.badge.img
  • 13 replies
  • June 26, 2025
Try going into your settings and turning on VOLTE  I had tge same problem until I done that and it's all sorted out now.
Forum|alt.badge.img
  • 13 replies
  • June 26, 2025
Let me no what happened please if it sorted it out.
Siân W
  • 1376 replies
  • June 27, 2025
Hi ​@KingSabaroche  how did you get on?
Forum|alt.badge.img
  • 13 replies
  • June 28, 2025
How is going.? Did you try switching the VOLTE on?? Ifso! Did it work ??
