Network and Call Issues
  • January 2, 2025
  • 431 views
I have an Iphone SE Gen2 and recently been having an issue where calls will not come through.
My husband for instance will call me, it rings all the way to voicemail - I get no notification of an incoming call - no missed calls etc.
I am also having issues making outbound calls. - it doesn’t ring, it just hangs and then disconnects.
I have updated the phone to the latest IOS - reset network settings etc etc
I cant contact IdMobile - obviously hey are now an “Online” only customer service team which I use lightly as after waiting 90minutes on their online chat they simply disconnected with the message “Our Team is Unavailable”
Never thought I would have to turn to an online forum for help rather than customer service.
So I am short of giving up unless someone here can help?
Best answer by Daz_S
Hi there ​@NathanjHarwood
Duly noted you’ve reset the network but have you also enabled VoLTE?
  1. *IMPORTANT* Enable 4G (LTE) and 4G (VoLTE) Calling.
Before enabling 4G (VoLTE) Calling, 4G MUST be enabled. To check, simply follow the steps below:
  1. Open ‘Settings’.
  2. Tap ‘Mobile Service’.
  3. Tap ‘Mobile Data options’.
  4. If you have a 5G capable iPhone, tap ‘5G Auto’ or ‘5G On’. If you have a 4G capable iPhone, tap ‘4G’.
  5. If you have a ‘VoLTE’ toggle, ensure this is switched ON.
Daz_S
  • January 2, 2025
  1. Open ‘Settings’.
  • January 3, 2025
Hey there ​@NathanjHarwood, sorry to hear that.
What’s your full postcode, and what phone do you have please?
Please also try the kind advice from ​@Daz_S.
  • January 3, 2025
i have me given the advice a go and everything is working again - time will tell if it drops again
postcode is ls27 prefer not to share full on a public forum
iPhone SE gen 2
Daz_S
  • January 3, 2025
That’s good to hear its working now ​@NathanjHarwood
Now you’ve adjusted the settings it should now be fine🤞
  • January 6, 2025
Glad to hear this is now working for you ​@NathanjHarwood
Please do get in touch if you require any further assistance.
Nat
