network and call issues again
  • January 23, 2025
  • 611 views
I have posted in this forum before and am so frustrated with the lack of support from id
we are having constant issues where those says it has a signal but is unable to receive calls.
calling the number and it just rings. The phone receives no notification of a missed call and can’t call out. It just hangs without dialling.
Have tried all solutions - restarting works for a while but there is no way of knowing when this error has happened.
I have done all the things related to the 3G switch off advised in this forum. Honestly will never go with a company again that’s online only with no customer service team, when things go wrong some support is needed.
any advice before I switch networks?
  • Helpful Contributor
  • January 23, 2025
ID mobile doesn’t have their own network, they use network of THREE.
It’s not the first issue with THREE network which is really frustrating because it affects ID mobile users as well.
My point is - don’t switch to Three because you will have all the same problems.
  • January 24, 2025
Hey there ​@NathanjHarwood, we're aware of a network wide issue that was affecting services, and we believe this has now improved, so please restart your phone and attempt to call. We sincerely apologise for any inconvenience caused, and really appreciate your patience.
Updates can be found here:
https://community.idmobile.co.uk/contacting-id-183/we-are-aware-that-some-customers-are-experiencing-issues-making-and-receiving-calls-72269
