Number has transferred for calls but not SMS
I recently joined iDMobile and transferred my number from 3 using the PAC obtained. My number has transferred and shows on the iDMapp and when making calls, but when I send SMS texts my messages appear from an unknown number, not my transferred number. Any suggestions? Thanks
Best answer by Tom
Hi @AWig
Are you still having issues with this?
Have you tried the above suggested network reset?
For iPhone;
For most Android;
For Samsung;
  • 12198 replies
  • May 30, 2024
Have you tried a NETWORK RESET, @AWig
Your handset user guide usually covers reset procedures.
  • 8336 replies
  • June 5, 2024
Hi @AWig
For iPhone;
For most Android;
For Samsung;
