Number problem with texts
  • November 22, 2024
  • 8 replies
  • 106 views
I've sent a couple of texts this afternoon and my phone is using the number attached to the sim provided by ID and not the one my phone should have switched to.  Previously it has worked fine.  Can you help, please.
Best answer by Kash
Hi ​@Bob Hewitt,
Please try the following, and let us know how you get on:
Alternatively, you can turn Chat Features/RCS off and test SMS after this.
  • 12349 replies
  • November 22, 2024
This community article might help, ​@Bob Hewitt
  • November 22, 2024
Thanks, but I've tried most of that but still not working properly.
  • 12349 replies
  • November 22, 2024
Okay ​@Bob Hewitt, are there some steps, in the article, you haven’t tried yet?
What device do you have?
  • November 22, 2024
No, tried them all now.
  • November 22, 2024
Samsung S24 FE
  • November 23, 2024
Hi ​@Bob Hewitt,
  • November 23, 2024
Hi, when i clicked on "Chat Features" it just turned the feature on and off, couldn't see any phone number!
Sent a text with the feature turned and it seems to have worked!
Thank you, Kash!
  • 8408 replies
  • November 25, 2024
Hi ​@Bob Hewitt
Glad to hear the above helped.
