I have a charge of £10 for out of plan charges added whilst on ferry Holyhead to Dublin. I did not use my phone, so why the charge. I switched phone off when I was notified I’d apparently used 80% of my cap and when I switched it back on promptly was notified I’d use 100%!!?? Why??
out of plqn charges
Best answer by MZone
Sounds like you connected to the Ferry’s mobile network. Even though you may not have used your phone the phone is always connected and downloading data in the background for updates/app notifications etc
When you’re at sea, we strongly recommend you don’t use your phone, and put it into flight mode until you get to shore. We’re advising this because roaming charges at sea can be very expensive.
If you’re going on a cruise, or taking a ferry on a journey like Dover to Calais, roaming charges could apply, even if you’re travelling between any of our ‘Inclusive Roaming’ countries.
The reason for this is because ferry and cruise operators often use their own phone network that’s operated via satellite. Connecting to a satellite network is much more expensive then connecting to a land operated network, so that’s why your usage at sea isn’t included as part of your Inclusive Roaming allowance.
Here’s a table showing the costs of roaming at sea:
Roaming | Pay monthly | Pay-as-you-go**** |
Calls to UK* | £6.00 | £6.00 |
Calls to Ships, Ferries, Cruise Liners* | £6.00 | £6.00 |
Calls received* | £1.50 | £1.50 |
Texts to Ships, Ferries, Cruise Liners** | £1.20 | £1.20 |
Texts to UK** | £1.20 | £1.20 |
Picture message (MMS) sent** | £0.60 | £0.60 |
Internet and Data (per MB)*** | £9.60 | £9.60 |
* Price per minute
** Please note: MMS charges vary. For further information, refer to Terms & Conditions. If you joined or upgraded on or before 20th June 2023 the MMS cost is £0.30 per message for Roaming within EU Bands 1 and 2.
**** The charges below will apply to all Pay-as-you-go customers starting from 1st October 2024. Find out more about the current charges here.
To avoid these high charges, we’d advise you not to use your phone when at sea. Just pop it in flight mode until you reach land.
Some ferry and cruise operators offer Wi-Fi on board, and you can still connect to Wi-Fi when in flight-mode. Simply go into your settings and manually turn on Wi-Fi.
Log in to the iD Community.
Social Login
Log in with FacebookPlease enter your email address. If it matches our records, we'll send you instructions to reset your password.
