PAYG
I have two questions regarding payg..
  1. Will my account remain active if I do not use or top up my sim?
  2. How does cancellation of payg work?
Best answer by Kash M
Hi  @FlowerGirl,
For information on leaving or cancelling you can visit the link below:
https://community.idmobile.co.uk/thinking-of-leaving-108
As per the terms and conditions.
12.4 Unless an additional Top-Up has been made, any unused Credit will expire after a period of 365 days from the date of purchase and unused allowances will expire as specified and this is non-refundable.
12.5 If you don't apply any Credit to your account, purchase a bundle, or make a chargeable event within 4 months of the expiry of the Introductory Period or, if later, the date you last applied Credit to your Account, your Account may be disconnected.
  • 8256 replies
  • October 6, 2024
Hi  @FlowerGirl,
  • 10 replies
  • June 21, 2025
I have a £10 per month PAYG.  If after 1 month I do not continue to pay, will calls, texts , data be charged at the PAYG rate off the £10 until expired ?
  • 8584 replies
  • June 23, 2025
Hi ​@Toad008
I’m not sure what you mean, if you have a Pay As You Go plan, you’ll pay for what you use or pay for bundles within the app.
  • 10 replies
  • June 23, 2025
With the older conventional PAYG, you paid up front and the amount was debited as you used it.
i.e   calls  25p/ minute     text   5p say,  data  10p  a Mbyte  say.
With IdMobile PAYG these are unlimited text and calls for 1 month.
If I did not pay the additional £10 after 1 month how does it continue ?
Is the £10 then debited like the old PAYG until used up  ?
Alan
  • 5495 replies
  • June 24, 2025
Hey there ​@Toad008, we used to offer re-occuring bundles where you were charged monthly for the same bundle, however, these are no longer offered. Therefore, you will need to purchase a new bundle each month after the current one expires, if that makes sense.
If after the bundle expires, you don’t purchase a new one, you wouldn’t be charged until you did purchase another one later on.
  • 10 replies
  • June 24, 2025
No, question still not answered.  Strange I thought it was simple.
I will just have to see what happens with the payg account and work it out for myself.
BW
Alan
  • 2349 replies
  • June 24, 2025
Hi ​@Toad008
Can you please advise on what you need answering and we will do our best to help?
Natalie
  • 10 replies
  • June 24, 2025
Its very simple.
If I do not renew my £10 per month payg subscription, what happens to it, does it get used up with the standard payg rates ?
BW
Alan
  • 5495 replies
  • June 26, 2025
Hey there ​@Toad008, If you don’t renew the £10.00 PAYG subscription, then your PAYG will remain active with no credit on it, until you either top up or purchase another bundle again. So to confirm, if you purchase a £10.00 bundle, and don’t use all the allowances within a month, and then don’t re-purchase a bundle after the 1-month, then you’d have no allowances to use until you purchase another bundle or topped up again.
  • 10 replies
  • June 26, 2025
IdMobile advertise payg rates which actually they don’t do now.  The payg system offered is almost the same as a monthly account, with no contract.
“iD Mobile Pay As You Go (PAYG) rates include 3p per minute for calls, 2p per text, and 1p per MB of data, according to iD Mobile Community. “
Giffgaff do exactly what I want, true payg for use in a tracker, so i will go to them.
Alan
  • June 29, 2025
That’s not correct. With PAYG, if you let whatever bundle you are buying expire you get switched to 3/2/1 PAYG.
To use true PAYG , be sure to only top up your credit. Do not buy a bundle.
I’ve been on 3/2/1 PAYG for around three years (spare phone). Remaining credit is shown correctly, it all works just fine.
AFAIK, new customers can’t got straight onto true PAYG, have to buy a bundle for the first month, let it expire, then top up credit.
call charges
“If you have a Pay as you go (PAYG) plan with iD Mobile you can either purchase one of our six Pay as you go bundles, or literally pay as you go using the Top-up credit on your account.”
  • 10 replies
  • June 30, 2025
Good.
Finally the right answer which I thought was the case all along.
Hopefully test it the end of the month.
BW
Alan
  • 10 replies
  • July 29, 2025
No it did not work.  Once the monthly £10 date came it did allow remainder usage on a PAYG price basis.  I had hardly used it.
Over to GiffGaff then !!
  • 8584 replies
  • July 29, 2025
Hi ​@Toad008
I’m not sure what you mean, what about it didn’t work?
  • 10 replies
  • July 29, 2025
From previous answers, it said the PAYG tarriff would revert to pay by minute etc when the month had ended, and no more was paid in, to use up.  It does not, service just stops.  It is no different to a normal monthly SIM.
Giffgaff does what I want perfectly, true PAYG which was common in the past.
  • 8584 replies
  • July 29, 2025
Hi ​@Toad008
That is what should happen, if there’s top up credit, it’ll use that, if there isn’t any it can’t use it.
I’m sorry we don’t have what you need, we wish you the best of luck with Giffgaff.
  • 10 replies
  • July 29, 2025
OK.  But my monthly SIM is excellent.  I like the data carry over, gives oodles.
  • 5495 replies
  • July 30, 2025
We’re glad to hear you like your monthly SIM ​@Toad008.
