Problem With Switch
Big_Micky
I have given my PAC to ID Mobile. I got a message from 3 that my number has been ported, so my phone number doesn’t work any more.
Putting my new SIM into my phone, I am getting a SIM Failure error message.
When I attempt to login to my account online, it asks for a OTP from an SMS from the original number ID assigned me, but I can’t access the SMS because the SIM isn’t working.
Now I have no network coverage at all.
Any ideas how to resolve this?
Get a replacement SIM card from iD Mobile, @Big_Micky
These forum articles should help in this situation.
  • 12531 replies
  • May 3, 2024
Icantthinkofausername
I can't receive calls.
phone sends out an on another line message!
please fix this asap.
Big_Micky
  • May 3, 2024
That doesn’t help me for the next few days, with my old SIM switched off and having to wait for the new one to arrive.
  • 12531 replies
  • May 3, 2024
If your handset supports eSIM devices, you could get an eSIM replacement (by email) pretty much straight away, @Big_Micky
Otherwise, pick-up a physical replacement SIM from your nearest Currys store.
Big_Micky
  • May 3, 2024
Does an iPhone 11 pro support esim?
Having to make a special trip to Curry’s really is a lot of effort for what I expect to work in the first place.
  • 12531 replies
  • May 3, 2024
Okay @Big_Micky, the Apple tech spec for iPhone 11 Pro says it’s got dual SIM capability - nano-SIM and eSIM.
Easily double-check if your iPhone is eSIM compatible - dial *#06# into your keypad. If you then see a screen, which includes an EID number, your device is eSIM compatible.
  • May 4, 2024
Hi @Big_Micky,
I hope that your issue is resolved.
