I was hoping to gain some insight into the new website bugs and issues.
When going to set up a new direct debit it allows me to put all my details in, however when i press the confirm button on the bottom, it comes up with the same error everytime that the details cant be saved.
Hopefully this gets sorted soon as i would like to set up a direct debit.
Hope to hear back from a technician soon.
Thank you in advance.
kieran akers
Alas, nothing happens quickly in the iD community, @kieran akers.
This forum article seems to suggest a new direct debit instruction can only be setup using the iD app or “My iD Account” online service. Neither is currently reliable, nor can you always login.
You could give your feedback using the following links, @kieran akers.
If you have any issues with the direct debit, please let us know.
You still can’t amend any direct debit details. Logging in was always fine it was trying to add a direct debit so that I can look into my plan details.
Hey there Kieran, we’re very sorry to hear that. For the direct debit your adding, does the bank card match the details linked to your iD Mobile account/your personal details please?
yeah all details are correct which is only my address and name… still cant set up a direct debit in order to make my payments easier.
I’d recommend making sure that the details used in the iD Mobile app/website when setting up the direct debit match exactly to the details you have with your bank (Name, Address etc).
If you’re still having issues with this, we’d recommend calling as a one time exception 0800 049 2376 to change your direct debit details over the phone.
Not the answer you were looking for?
Create a new topic and ask a question to the iD Community.
