signal issues
Hi, 3 samsung phones in our house all on id. 2 phones have a great signal but 1 is terrible. Any ideas to fix this? Sim in other phone works fine.
Best answer by Tyler
Hey there @Pitz, thank you for reaching out.
As @andewhite has kindly suggested, this does sound more like a faulty device. Where did you get this device from and when did you purchase it please?
  • 12348 replies
  • June 8, 2024
Sounds like you might’ve answered your question, @Pitz.
If the SIM from the suspect handset works perfectly in both of the other handsets, then perhaps you’ve got one faulty or misconfigured device.
What do Samsung say? I think there’s a field test app for Samsung phones in the Play Store (from Samsung).
  • 4175 replies
  • June 20, 2024
