travelling abroad
  • January 26, 2025
  • 60 views
Will I get I get charged using minutes texts and data whilst on holiday in the Canary Islands?
Best answer by Tyler
You’re very welcome ​@Rampton92!
Have a lovely time away :)
  • 3947 replies
  • January 27, 2025
Hey there ​@Rampton92, you can roam in the Canary Islands like you can at home, and use data, calls and texts as you would in the UK, please see below:
https://www.idmobile.co.uk/help-and-advice/eu-roaming
If you joined/upgraded on/past 20st June 2023, you will be subject to the 30GB data fair usage policy. If your data allowances is lower than 30GB, your limit will obviously be your normal allowances, please see below:
You will need to enable roaming via the iD Mobile app/website and also via your phones own settings to use the phone. Please read the below for instructions on how to get set up:
https://community.idmobile.co.uk/community-archive-140/how-to-prepare-your-phone-for-a-trip-abroad-182
  • January 27, 2025
I appreciate your help thank you
  • 3947 replies
  • January 29, 2025
