Have gone through previous comments but cannot get WiFi calling to work (it used to) which renders my phone useless inside my house if I want to make a call.
wifi calling not working on both iphone 14pro and iphone 15pro
Best answer by WelshPaul
Then the problem isn’t with iD Mobile or your handsets but with Wessex Fibre 5G or the router they provided you with.
Some useful information can be read here:
https://www.ispreview.co.uk/talk/threads/vowifi-wifi-calling-technical-details.41366/
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
Log in to the iD Community.
