Data Roaming not working in Spain
Arrived in Spain today. Received the text message from Rate Advice saying I could roam free but even though it shows 4g or 3G on my iPhone 13, I’m still not able to get online. Reset all network settings but still nothing. Very frustrating!!!
just get a message saying could not activate mobile data network, as shown below. Any ideas?
  • 7962 replies
  • July 24, 2023
Hey @Ceekay75,
Is Mobile Data turned on?
Have you also enabled “Data Roaming” in the phone settings?
Both of these need to be on for data roaming to work.
Note, “Data Roaming” is a separate setting in your phone settings to that of “Roaming” which is found in the app/account.
The “Roaming” option in the app turns on the ability to roam.
The “Data Roaming” option in your phone settings allows your device to access mobile data when abroad.
  • July 24, 2023
Hi Mohammed,
Thanks for replying. Managed to get it working using the thread Here
Not sure why iD continue to sell iPhones without the option to edit the APN.
craig
  • 12408 replies
  • July 24, 2023
Ceekay75 wrote:
Hi Mohammed,
craig
I suppose you could ask the same of Apple, because @Peroni93 bought their iPhone directly from Apple.
I’d guess it’s more likely to be a network operator issue (iD Mobile), because the option to edit your handset APN settings is available on other UK networks, e.g. SMARTY (also using the Three network), Vodafone, etcetera.
If you asked Apple support about this, I suspect they’d tell you to speak to your carrier.
  • July 24, 2023
@andewhite is correct. Apple say take the issue up with your carrier. It seems the sim itself is capable of telling the phone whether to show APN settings or not. iD have definitely clicked a wrong setting for their business network settings.
Smarty mobile is excellent by the way 🤣
  • 12408 replies
  • July 24, 2023
I guess that because there’s #LessMalarkey, #MoreSMARTY @Peroni93 🤣
  • July 24, 2023
Haha you know it!! 100gb for £12? Cmon you cant not! @andewhite i swear im not on the payroll
  • 12408 replies
  • July 25, 2023
Nice one @Peroni93 - is that £12/month deal in Crypto or Cash?
