Voicemail not set up fully
Federico Sirolla
Hi when I call the voicemail on my phone and enter my phone number and then the hash key it says your mailbox has not been setup fully. I have tried switching voicemail off and on the iD Mobile app but the problem still persists. Could you help me?
Federico Sirolla wrote:
I am currently abroad. I have been dialling 123, if I stay on the line it says to call your voicemail to setup your mailbox but I am calling the voicemail so I don’t know what to do.
Is me being abroad the cause of this problem?
I don’t think you can setup iD Mobile voicemail when you’re abroad - it needs to be setup when you’re in the UK @Federico Sirolla.
  • 3054 replies
  • July 7, 2023
Try turning off voicemail via your online account and leave it off for 24 hours before turning it back on.
  • July 9, 2023
Hi @Federico Sirolla,
Just checking how you got on from the advise that @WelshPaul provided?
Federico Sirolla
Hi I have tried @WelshPaul’s suggestions but it still does not work. Could you help me?
  • 7962 replies
  • July 10, 2023
Hey @Federico Sirolla,
Are you in the UK currently or abroad?
Are you able to stay on the line and follow any steps to set this up?
What number are you ringing for voicemail?
Have you tried dialling 123?
Federico Sirolla
  • 12408 replies
  • July 10, 2023
  • 7962 replies
  • July 10, 2023
This will be the issue, you need to setup when you’re in the UK.
As you need to set a PIN I believe for when dialling abroad.
  • September 19, 2023
Hi. I have the same situation and am a new customer. I’m in and out of the UK constantly and find this really unhelpful. I’ve got important calls and need to be able to access my voicemail asap BEFORE returning to the UK this weekend. What can be done in this case?
  • 3054 replies
Nothing! You need to setup your account and any related services while your in the UK.
Thanks WelshPaul. Are you an IDMobile employee or answering as a customer?
  • September 20, 2023
Hi @CMcG1882,
@WelshPaul isn’t an iD Mobile employee.
As @CMcG1882 as @Mohammed advised you need to setup when you’re in the UK.
