Nov 14, 2025 10:36 PM UTC
5G connection and data too low ?
    Nov 14, 2025 11:09 PM UTC
    Congestion most likely.
    Nov 20, 2025 9:33 PM UTC
    Dec 8, 2025 8:24 PM UTC
    Dec 8, 2025 9:24 PM UTC
    Why do you keep posting screenshots? There is no minimum speed guarantee. You get what you get!
    Lamiya C
    Dec 9, 2025 11:06 AM UTC
    Hi ​@Konstantins ,
    Thank you for sending the screenshots through. To make sure I can help you correctly, could you please confirm what issue you’re experiencing with your network service?
    Are you reporting slow speeds, loss of signal, or something else? Once I have a bit more detail, I’ll be able to look into this further for you.
    Lamiya
    Dec 9, 2025 12:47 PM UTC
    Hi yes the problem is the data som time 0 and i cant reseve the jobs as im delivery driver and i receveng jobs ower the mobile app
    Dec 9, 2025 8:06 PM UTC
    You can say get what you get if that is for free not if customer pay money for servive!
    Zubeida H
    Dec 10, 2025 10:50 AM UTC
    Hi ​@Konstantins
    We do understand how frustrating this may be, we do apologize for the congestion. Please try doing a network reset to see if that will make your connection any better.
    Thank you.
