network issues
For the last few weeks I have been unable to get a strong data connection in the nn8 1aq area. I used to get 5g now I am struggling to load simple websites. Please could someone look into the mast efficiency.  Thank you.
Best answer by Tom
Hi ​@Kelvinjw
Taking a look the area of NN8 1AQ is very weak for 5G, we’d recommend switching to 4G whilst in the area.
MZone
  • 1121 replies
  • March 11, 2025
  • March 11, 2025
I have checked that and no issues reported thanks for the response though.
  • 8352 replies
  • March 11, 2025
Hi ​@Kelvinjw
  • March 11, 2025
I normally have a stable 4g but recently data quality has been poor a video call is just about possible with poor image quality. Haven't had problems up until now.
  • 3991 replies
  • March 12, 2025
Hey there ​@Kelvinjw, sorry to hear that.
When did issues begin?
Does it affects texts and calls?
  • March 12, 2025
Hi ​@Tyler  I noticed there was no 5g around the 27th of feb and the issue has progressively gotten worse since then. Calls seem ok, texts are a little slow but come through, data on the other hand is tedious. I don't have issues back home just at the stated postcode area.
  • 3991 replies
  • March 13, 2025
Hey there ​@Kelvinjw, we're working on fixing an issue in this area at the moment. We're sorry for any disruption this may be causing.
We hope to have things fixed as soon as possible and will add any updates here.
https://www.three.co.uk/support/network-and-coverage/coverage?tab=2#tabs-c2d0d12ce8-item-2988999184-tab
