No mobile connection indoors KY9 1LG
I moved to KY9 1LG and even though I checked the coverage for 4g I have absolutely no signal inside the house and all I get is exclamation ‼️ mark at the 4g triangle. When I do go outside there is not very good signal as stated but weak and poor signal as cannot (or takes forever) load any apps/webpages with graphics and really only basic emails can be read , any attachments are a nightmare as takes forever.
  • 12418 replies
  • June 2, 2025
Sadly the iD Mobile online coverage checker (like the other UK service providers) is only a theoretical prediction of signal reception, at any given UK location, ​@abb1968
Unfortunately, your actual coverage may be better or worse than predicted, for any given location.
The https://mastdata.com online site might have actual signal reception information for your location.
You could try using the iD WiFi Calling service at home.
  • 8408 replies
  • June 3, 2025
Hi ​@abb1968
I’m sorry to hear this, the area of KY9 1LG does look a little patchy so this could affect service around here, how are other areas?
