phone not sending or receiving calls
When can I expect my id mobile phone to start being able to make and receive calls
Best answer by Natalie W
Hello ​@Eric Heavisides
A network wide issue was identified and we can advise 3UK have confirmed that services are now fully back to normal, apart from some localised issues related to Storm Éowyn.
All updates are available here
We apologise for an inconvenience caused by the issue and want to thank you for your patience and understanding whilst we got this repaired.
If you are still experiencing issues, can you please try rebooting your handset and let us know how you get on?
Nat
Forum|alt.badge.img+21
  • 2215 replies
  • January 24, 2025
Nat
  • January 24, 2025
Now working as it should to my relief
  • 8 replies
  • March 26, 2025
unable to receive phone call since switch over to ID mobile esim
  • 4172 replies
  • March 26, 2025
Hey there ​@carol gray, sorry to hear that.
When you go into phone settings, is your phone number showing correctly?
  • 8 replies
  • March 26, 2025
yes it is I was keeping my old number
  • 8 replies
  • March 26, 2025
can you update. I am unable to receive phone calls and text messages. Switch date was 24/03/25 I was keeping my old number which is shown correctly
  • 4172 replies
  • March 28, 2025
Hey there ​@carol gray, are texts and data working okay for you?
Is the issue only with receiving and making calls please?
  • 8 replies
  • March 28, 2025
NO Still can’t receive phone calls or text messages thinking of leaving ID mobile as live chat not helpful and no response from technician so far very disappointed
Decembersangel72
Silver Contributor
Forum|alt.badge.img+12
Hi ​@carol gray
What phone do you have?
Some phones get confused if a physical SIM is installed when an ESIM is being used and the settings are not set correctly to reflect this. Is this the case?
This will help in trying to determine the problem.
x x
  • 8 replies
  • March 29, 2025
I have an Iphone 14 with eSim still not receiving texts or phone calls if not sorted today will be cancelling my order
  • 8 replies
  • March 29, 2025
showing error at activation have tried all the troubleshooting but still not working and can’t update apple account as need verification code sent via texts which i can’t receive
Decembersangel72
Silver Contributor
Hi ​@carol gray
Unfortunately, it seems that you can’t get a verification code sent via email but only as a text to a trusted device (which seems like an oversight by Apple to me).
Is there a physical SIM in the handset? If so, then try removing it and restarting the phone.
Or just try turning your phone off and turning it on again (worth a try as sometimes the simplest answers are the ones that work).
Is the software up to date on your handset?
How is the internet connection when trying to activate the eSIM?
Have you contacted Live Chat to see if they can supply you with a replacement eSIM? It may be that the one you were sent was faulty (just like some physical SIMs).
I hope you find an answer x
  • 8 replies
  • March 30, 2025
thanks tried all of the above still not resolved pity physically talking to some one not an available option with ID mobile 😩
  • 4172 replies
  • March 31, 2025
Hey there ​@carol gray, we’re sorry to hear you’re still having issues.
Would you be happy to try a free, replacement SIM card? If so, please take a look how to do so here:
This would hopefully resolve your issue.
  • 8 replies
  • March 31, 2025
is that going to take me another week without being able to receive or make phone calls and texts. Had a Text from ID mobile today to say issue was resolved. Afraid NOT all still sending texts messages and face time as my email addresss trying to change but just coming up with activation error try again. Have reset network but still NOT working extremely disappointing with this service
  • 2215 replies
  • March 31, 2025
Thanks for your reply ​@carol gray
There are a few different options for a replacement SIM which means varied delivery times.
Sent via DPD (1-2 working days, signature/delivery photo required)
Visit any Currys store
eSIM sent via Email (Please ensure your device is eSIM compatible and you can currently receive SMS before requesting this)
Natalie
Decembersangel72
Silver Contributor
Hi ​@carol gray
I have found this……
https://support.apple.com/en-gb/102478
It may be worth deactivaying and the reactivating the eSIM…..
To deactivate an eSIM on your iPhone 14, go to Settings > Cellular/Mobile > [Your eSIM] and toggle the "Turn on this line" switch to off.
Here's a more detailed explanation:
  • Access Cellular Settings:
    Open the "Settings" app on your iPhone 14 and tap on "Cellular" or "Mobile".
  • Select the eSIM:
    Under the "DATA PLANS" list, select the specific eSIM profile you want to deactivate.
  • Toggle the Switch:
    On the eSIM's settings page, you'll see a switch labeled "Turn on this line" or similar. Toggle this switch to the off position to deactivate the eSIM.
  • Reactivate if needed:
    To reactivate the eSIM, simply toggle the same switch back on.
Quick note….. you need to have the phones WiFi connection turned on and connected to be able to activate your eSIM.
I really do hope you find an answer x
  • 2215 replies
  • April 5, 2025
Thanks for supporting with this ​@Decembersangel72
Natalie
Decembersangel72
Silver Contributor
You are VERY welcome ​@Natalie W 😁
I just hope you find an answer x x
