Signal coverage
I have terrible signal at my house, for some reason when calls come through they don’t go through WiFi calling and I just get voicemails (which I then can’t dial up at home). My WiFi works fine for emails, watsapp etc. I’ve switched on WiFi calling but am I doing something wrong?
Best answer by Tyler C
Hey there @JennieP, we're very sorry to hear you're having issues with coverage.
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please do let us know.
  • 12433 replies
  • July 2, 2024
Unfortunately @JennieP, unless your handset has a Settings option for WiFi Calling PREFERRED, you’ll need to use flight-mode with Wi-Fi turned on to force your handset to use WiFi Calling at home.
Tom B
  • 8408 replies
  • July 16, 2024
Hi @JennieP
I’m sorry to hear this, how long have you had issues here?
Please could you let us know the postcode(s) where you’re having issues?
  • July 16, 2024
Thanks, I’ve had issues since I switched over to ID a few months ago,  it’s NR8 6UD. I’ve tried switching on airplane mode but this doesn’t work either. Thanks
  • 4697 replies
  • July 30, 2024
