Suddenly no signal
  • September 12, 2024
  • 314 views
I’ve been with ID for nearly two years and never had any issues. However from last week, when I am at work, I have no signal. I can occasionally get 4G in certain parts of the building but have no bars. Never had this issue before! Always been slow but never completely gone. Worrying because family cannot contact me in an emergency.
Best answer by Tyler C
Hey there @Maddiewynne1, we're very sorry to hear you're having issues with coverage.
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please do let us know or contact us via our live-chat:
Have you also tried some of the troubleshooting methods below?
https://community.idmobile.co.uk/troubleshooting-177
Geluk
Silver Contributor
Forum|alt.badge.img+10
  • Silver Contributor
  • 469 replies
Put your postcode in here to see if there are local issues;
  • 12535 replies
What’s the signal like outside the building, @Maddiewynne1
Can you use the iD WiFi Calling service while you’re at work?
  • 5223 replies
