is roaming in lanzarote free
Adam Morris
Does lanzarote come under Spain when roaming?
Best answer by Tyler
Hey there @Adam Morris & @swcq, you can roam in Lanzerote/Spain like you can at home, and use data, calls and texts as you would in the UK, please see below:
https://www.idmobile.co.uk/help-and-advice/eu-roaming
If you joined/upgraded on/past 21st June 2023, you will be subject to the 30GB data fair usage policy. If your data allowances is lower than 30GB, your limit will obviously be your normal allowances, please see below:
You will need to enable roaming via the iD Mobile app/website and also via your phones own settings to use the phone. Please read the below for instructions on how to get set up:
https://community.idmobile.co.uk/community-archive-140/how-to-prepare-your-phone-for-a-trip-abroad-182
  • Helpful
  • 31 replies
  • June 26, 2024
Going there myself soon so I  hope so
It's part of Spain so yes
  • 4103 replies
  • July 9, 2024
