I am going to Canada in June do you have any plans for that will be taking 4 lines out there 2 my and 2 of my friends are going well all on id
Many thanks
Barry
Many thanks
Barry
Best answer by MZone
The table below displays how much you’ll be charged for any minutes, texts or data that you use.
Roaming | Pay monthly | Pay-as-you-go**** |
Calls to UK* | £6.00 | £6.00 |
Calls to Canada* | £6.00 | £6.00 |
Calls received* | £1.50 | £1.50 |
Texts to Canada** | £1.20 | £1.20 |
Texts to UK** | £1.20 | £1.20 |
Picture message (MMS) sent** | £0.60 | £0.60 |
Internet and Data (per MB)*** | £9.60 | £9.60 |
* Price per minute
** Please note: MMS charges vary. For further information, refer to Terms & Conditions. If you joined or upgraded on or before 20th June 2023 the MMS cost is £0.30 per message for Roaming within EU Bands 1 and 2.
**** The charges below will apply to all Pay-as-you-go customers starting from 1st October 2024. Find out more about the current charges here.
You would probably be better off buying a local SIM or travel SIM.
