Roaming Charges
I am worried about roaming charges- I am in Spain and I read that you need to switch on roaming in your ID app but I can’t get access to the app only my online account is accessible but it doesn’t have the ability to switch on ‘roaming’ I have no idea what is going on - I am using my phone without WiFi as there isn’t any where I’m staying- I’m worried
You can use your UK plan allowances in Spain, @JadyG
Spain is one of the inclusive EU roaming destinations. To avoid any out-of-plan charges while roaming with your iD SIM, just set your iD account bill cap to £0.
There’s more online at https://www.idmobile.co.uk/help-and-advice/eu-roaming.
  • 12167 replies
  • July 4, 2024
  • 3801 replies
  • July 17, 2024
Hey there @JadyG, welcome to Community!
You can roam in Spain like you can at home, and use data, calls and texts as you would in the UK, please see below:
If you joined/upgraded on/past 20st June 2023, you will be subject to the 30GB data fair usage policy. If your data allowances is lower than 30GB, your limit will obviously be your normal allowances, please see below:
You will need to enable roaming via the iD Mobile app/website and also via your phones own settings to use the phone. Please read the below for instructions on how to get set up:
https://community.idmobile.co.uk/community-archive-140/how-to-prepare-your-phone-for-a-trip-abroad-182
