roaming not working
  • June 16, 2025
  • 67 views
Tiegan Ball
hi nat i’ve paid £40 for roaming data in turkey as that’s where i am… i brought it HOURS ago and i cant use it and all of my roaming things are turned on so why can’t i use it ?
Siân W
Forum|alt.badge.img+19
  • June 17, 2025
Sorry to hear this ​@Tiegan Ball
Can you please double check that you have enabled roaming - How do I enable Roaming? | iD Mobile Community
Can you please try rebooting your handset?
Tiegan Ball
  • June 18, 2025
roaming is on and i’ve tried everything! when i get back to the uk i will be ringing id mobile and getting my money beck and if not possible i will be leaving because this isn’t the first issue i have had with id mobile it’s rubbish !
  • June 19, 2025
Thank you for getting back in touch.
We are sorry to hear this ​@Tiegan Ball. Can you please try searching for a network manually?
When you do this you should be presented with options to select, can you please try each of these to check if the service works?
Natalie
