usa roaming add on
Hi.am going to usa later in year. I see I can buy a roaming data add with id mobile, which is fine, but am little confused, will this only be for data, or would it cover calls/texts to uk to, o will i be charged,extra for those?
Best answer by MZone
It is purely a data add on and you will be charged for any other type of usage.
You may want to consider a travel SIM/eSIM if you want to use your phone as you normally do.
Roaming charges in United States (USA).
The table below displays how much you’ll be charged for any minutes, texts or data that you use.
Roaming Pay monthly Pay-as-you-go****
Calls to UK* £1.68 £1.68
Calls to United States (USA)* £1.68 £1.68
Calls received* £1.50 £1.50
Texts to United States (USA)** £0.42 £0.42
Texts to UK** £0.42 £0.42
Picture message (MMS) sent** £0.60 £0.60
Internet and Data (per MB)*** £0.30 £0.30
* Price per minute
** Please note: MMS charges vary. For further information, refer to Terms & Conditions. If you joined or upgraded on or before 20th June 2023 the MMS cost is £0.30 per message for Roaming within EU Bands 1 and 2.
**** The charges below will apply to all Pay-as-you-go customers starting from 1st October 2024. Find out more about the current charges here.
MZone
  • 1213 replies
  • March 21, 2025
* Price per minute
  • 4641 replies
  • March 21, 2025
Hey there ​@Charlene Hewson-Sainty, thank you for your question.
That’s correct, they’re only for data.
Calls and texts would be charged as out of contract charges. Please see below:
Thank you both for the answers
Mzone thank,yoi, if I bit a,travel Sim, I guess I,will,thrn pay similar charges to oit of cintract prices,with ID, to call/text back to  uk , as,I do,not need to make,class in,usa,to usa. I guess best thing would be to use data only messages,in what's app etc as, its only for a wek?
Forum|alt.badge.img+1
  • Helpful
  • 53 replies
  • March 23, 2025
I would’ve actually just recommend buying an eSIM from a provider, Over there like Tello or something! It will be a lot cheaper
Personally, I use EscapeSIM, A 20 GB Sim card with EscapeSIM will be £15 after currency conversion
Ultimately it’s up to you, but it will probably work out a lot cheaper than buying a add-on from ID Mobile
to put that price into context for you if you would use 10 GB of data while roaming in the USA on ID Mobile it would cost you £30, as it is 30p per megabyte
