call dropping after 2 minutes and 5 seconds
Kevin Hindson
Isn't it time id mobile came up with a reason why calls drop after 2 minutes and 5 seconds. I'm not the only person who has this problem but they blame the SIM card the phone the area never a fault in there network
Forum|alt.badge.img+21
  • 2311 replies
  • February 5, 2025
Hello ​@Kevin Hindson
We are very sorry to hear your calls are disconnecting.
Can you please confirm the handset make/model?
Also, are texts and data working without issues?
Nat
Kevin Hindson
  • 22 replies
  • February 5, 2025
Motorola G54 5g
Kevin Hindson
  • 22 replies
  • February 5, 2025
Calls are very hit and miss and have to either restart phone or toggle airplane mode regularly to make calls. Phone was checked in Currys and new SIM card tried but still getting issues
Kevin Hindson
  • 22 replies
  • February 5, 2025
Texts are unaffected
  • 4825 replies
  • February 6, 2025
Hey there ​@Kevin Hindson, sorry to hear that.
Is this every phone call you make, cuts off at 2 minutes and 5 seconds? No matter who you call, what time you call etc?
Kevin Hindson
  • 22 replies
  • February 6, 2025
No mainly in the mornings but different people. One person on Tesco mobile and one on gifgaf network
  • 12461 replies
  • February 6, 2025
Perhaps there’s an issue with call handling/routing between the Three UK and O2 mobile networks, ​@Kevin Hindson
The MVNO companies Tesco Mobile & giffgaff both use the O2 network - good luck getting things sorted.
Kevin Hindson
  • 22 replies
  • February 6, 2025
Unfortunately probably have to change back to Tesco mobile as I never got these issues on there network
Kevin Hindson
  • 22 replies
  • February 9, 2025
Seems to be an issue on id mobile as other people have this issue
  • 2311 replies
  • February 11, 2025
Hi ​@Kevin Hindson
Thank you for confirming.
Just to rule the handset out, are you able to use the SIM in another handset and make a call to a number you have the issues with?
I suspect you may still have the same issue but it would confirm the issue lies with the SIM/network.
Nat
  • April 7, 2025
Did anybody find a solution to this issue?
I have exactly the same issue which occurred when I transferred from a physical id mobile SIM card to a e-sim.
Been on live chat but they are unable to resolve the issue.
Kevin Hindson
  • 22 replies
  • April 7, 2025
No they tried to blame my phone. But Currys said nothing wrong with phone it's a network issue but id mobile not admitting there is an issue
JoeKing
Silver Contributor
Forum|alt.badge.img+9
  • Silver Contributor
  • 386 replies
  • April 7, 2025
@Kevin Hindson  I had similar problem both with Virgin mobile at the time then EE and even with IDM when I joined over a years ago. There was a data error when my number was ported over which I'd informed each network at the time. I got all sorts of replies like it's my device, sim card communication tower etc etc. I had the use of 10 devices mainly Android and a few iPhone to test said problem. In the end I told the call handers that I know what I'm talking about as I work in this industry my tickets each time went to Technical support and after investigating the problem it was data error on the porting of my number. I'm not saying this  could be your problem but not everyone working in the industry has the IT or Telecom engineering knowledge to pin point network problems am afraid. Even a bad batch of sim card could be blamed for a few problems.
Joe
  • April 7, 2025
What phone do you have?
My wife and myself are using a Google pixel and have exactly the same issue.
Kevin Hindson
  • 22 replies
  • April 7, 2025
Motorola G54 5G
Kevin Hindson
  • 22 replies
  • April 7, 2025
Tried replacement SIM card but same issue.
  • 3086 replies
  • April 7, 2025
Same thing was reported and discussed by SMARTY users.
The issue seems to be that on 4G calls (and I think WiFi calls) the network requires the handset to periodically send in a keep-alive message during the call, to let the network know that the call is still active. And some Android handsets send the keep-alive signal in a format the network equipment doesn't recognise.
So I'm guessing Three's/iD Mobile’s/Smarty's network tells the handset to send the keep-alive message every 2 minutes. Your handsets are probably doing this, but in a format the network doesn't recognise. So after waiting a few seconds' grace period, the network decides it hasn't received a valid keep-alive message, so the call must be over.
https://community.smarty.co.uk/t5/chats-hacks/incoming-calls-end-after-2-mins-5-secs/m-p/25151
Kevin Hindson
  • 22 replies
  • April 13, 2025
Leaving IDmobile and going to try lebara as my sister is on it with no problems. I can't put up with this diabolical service. Can only make calls 50% of the time and when I can I get cut off after 2 minutes 5 seconds.
Kevin Hindson
  • 22 replies
  • April 20, 2025
Put my SIM into my old phone and works fine so IDmobile do not support Motorola G54 5G phones and probably a lot of other phones by the sounds of it. I now have a lebara SIM in my Motorola G54 5G and working without any issues so it is IDmobile network issues for definite
  • 3086 replies
  • April 20, 2025
Why isn’t it Motorola’s fault?
iD Mobile provide a list of approved handsets as do other networks:
The trouble with Android phones is that they come with a variety of customised firmware revisions that only work on certain networks.
Kevin Hindson
  • 22 replies
  • April 20, 2025
Motorola G54 5G is on the supported list
Kevin Hindson
  • 22 replies
  • April 20, 2025
That's why it's not Motorola's fault
  • 3086 replies
  • April 20, 2025
Who supplied you with the device? What firmware revision is it running?
There are a couple of disclaimers on the supported device list:
All handsets provided with an iD plan go through extensive testing in order to ensure the handset is compatible with our network.
You can visit our SIM Free Phones page, to view a range of SIM free iD compatible devices.
Providing you purchased a device SIM free or from iD Mobile, and it’s on the list, it should work. iD Mobile and SIM free handsets have generic UK roms installed and should work on all networks.
Kevin Hindson
  • 22 replies
  • April 20, 2025
Argos and is fully updated to android 15
  • 3086 replies
  • April 20, 2025
Argos do sell SIM free handsets which run stock firmware, it should work.
